Date/Time: Fri, 03 May 2024 05:07:39 +0000
ACSIL method to get subgraph name from remote chart
View Count: 594
[2019-08-28 23:04:08] |
onnb - Posts: 661 |
I see sc.GetStudySubgraphName Any chance you can add these two? 1. sc.GetStudySubgraphNameFromChart 2. sc.GetStudySubgraphShortNameFromChart |
[2019-10-29 11:35:04] |
We can add the first one, but it would get the short name if it is set. Let us know if you need that.
[2019-10-30 18:54:25] |
onnb - Posts: 661 |
That would work for sureLet us know if you need that
We don't have immediate need as we have moved on from when we needed it last time. That said, the need for this api comes up every so often. If you don't do it now, no worries, I can always follow up on this thread next time the need comes up. |
[2019-10-30 22:38:36] |
Ok we will add the function.
