Date/Time: Sun, 19 May 2024 18:59:09 +0000
Fill to Daily Open
View Count: 502
[2019-08-28 18:21:50] |
6c7574686572 - Posts: 20 |
I would like a mountain chart that fills to the daily open, ideally with different colors for above/below. Is this possible to set up?
[2019-08-29 04:19:59] |
It is certainly possible to create a custom study for this. In general refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
