Date/Time: Sun, 02 Feb 2025 06:44:36 +0000
How to have multiple charts all in one pane?
View Count: 1112
[2019-08-28 17:16:46] |
Why do the other charts disappear? Are they overlapping each other?
[2019-08-29 03:55:59] |
User585019 - Posts: 27 |
Fixed the overlapping, thanks. Now when I want to draw on one of the charts and I go to the main layout to use the tools etc. on the control bar, clicking on anything makes all 4 charts reduce down. Just wondering if there is a way to have all 4 charts stay up while using the control bar/other tools. TIA |
[2019-08-29 05:07:34] |
That does not make sense. That is not even technically possible. Sierra Chart is not going to minimize those charts. But you can add a Control Bar to each individual chart so you do not have to use the one on the main window. Refer to: Control Bar: Window >> Control Bars >> Control Bar [1-12] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
