Date/Time: Tue, 07 May 2024 00:06:23 +0000
Display PNL in chart including commissions
View Count: 1681
[2019-08-28 15:56:26] |
User710679 - Posts: 43 |
Is there any way to display in the chart the PNL associate to the attached orders including commissions? thanks
Screenshot_28.png / V - Attached On 2019-08-28 15:56:08 UTC - Size: 5.5 KB - 280 views |
[2019-08-28 17:17:59] |
Not including the commission but there is an option to enable the display of the profit loss. Here is the option for this: Global Trade Settings Windows: Attached Order P/L Always (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-28 17:18:41
[2019-08-28 18:25:29] |
Yeah, i knew that. Just wondering if it was possible to show it including commissions. That would be very helpful Thanks a lot like always! |
[2024-04-25 21:53:31] |
jsandlan - Posts: 14 |
I have the same question. Is it possible to have the displayed P/L, as pictured below, where the display shows your actual P/L including commissions? I've attached a screen shot to illustrate the question more clearly. Here it says the P/L is 4.66P. I'm wondering if it's possible to have that calculation include the cost of commissions. So, hypothetically, if the P/L is 10.66P but there are 6P worth of commissions then the displayed P/L would be correct at 4.66P (10.66P - 6P = 4.66P). Date Time Of Last Edit: 2024-04-26 13:45:40
[2024-04-26 14:32:00] |
John - SC Support - Posts: 31419 |
Refer to the following setting: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
