Date/Time: Sun, 02 Feb 2025 06:41:07 +0000
renew what?
View Count: 643
[2019-08-28 12:39:17]
User143551 - Posts: 102
u say my time is about to expire in two days ,I use transact bridge 1941 ,infinity they charge me to use their charts , what do u want me to pay and why,give me a call when u can
[2019-08-28 18:09:11]
We will get back to you on this later today.
[2019-08-29 04:47:30]
You can either pay for Sierra Chart through your brokerage account with Infinity. There should be no price change for the month of September.
Or you can pay for Sierra Chart directly to Sierra Chart. If you run Sierra Chart using the shortcut on your desktop, you can then pay for usage time and take advantage of the 30% discount even if you pay month-to-month. After logging into Sierra Chart, select Help >> Account Control Panel from the menu.
And then follow the instructions here to pay for usage time:
Sierra Chart Purchase and License Information: Renewing Access
And once you are paying direct for Sierra Chart, you will just always launch Sierra Chart through the shortcut on your desktop. You would not launch it direct from the Transact software. You will continue to use the username that begins with Transact_user_.
Let us know if you need further help.
Date Time Of Last Edit: 2019-08-29 04:53:54
