Date/Time: Sun, 19 May 2024 17:40:45 +0000
[User Discussion] - Text Display for Study
View Count: 1236
[2019-08-28 08:04:30] |
samual sprat - Posts: 343 |
Hi, Is it possible to colour text based on positive or negative values? I've tried doing this but it doesn't work using 'Text Display for Study'. Maybe i'm not doing it right or there is another way to do it? Thanks S |
[2019-08-28 08:41:24] |
Ackin - Posts: 1865 |
Hi, Text Display from Study - Background based on positive/negative ?? | Post: 171850 or text lable display for a study |
[2019-08-28 09:10:58] |
Awesome. I'm already registered but i can't work out how to download the files. Do I need to send you my sierra username?
[2019-08-28 09:28:31] |
Sunny) Do I need to send you my sierra username?
yes..by email pleasezyp.sierra@gmail.com next steps: 1) Download attached file from upload folder (last page, last post), upload folder link is on the main page forum in the top right corner (or in the email) 2) Copy and Unpack this file into Data folder in Sierra Chart (default C:\SierraChart\Data\) 3) Run Sierrachart 4) Add custom study In the Sierrachart sw: Menu / Analysis / Studies Click on "Add Custom Study" where you'll find this new library. Update archive file contains files: zyp sierra free.dll - 32 bit version (Sierrachart) zyp sierra free_64.dll - 64 bit version (Sierrachart) There are currently about 140 free studies That's all Date Time Of Last Edit: 2021-01-19 19:12:39
