Date/Time: Thu, 06 Feb 2025 15:07:51 +0000
NYSE TICK
View Count: 1567
[2019-08-28 04:05:58] |
User530916 - Posts: 6 |
I am not sure what is going on, but the TICK-NYSE being provided by your feed is wildly different than all other feeds I use (2 more from independent providers). So much so that I can't get a proper read on the market using your TICK. Just a FYI in case anyone else has submitted a complaint. The problem is that your TICK wildly swings.
[2019-08-28 04:34:43] |
Refer to this section here: Sierra Chart Market Statistics: Market Statistics Calculations Compared to Other Data Services What we can say is that what you are seeing is very precise, and responds immediately to the price changes of the symbols on the NYSE. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-28 04:35:31
[2019-08-30 12:05:09] |
Another issue is the net issues of the NYSE. I'm using a DTN feed for reliable metrics as the ones provided by Sierra are unusable for me.
[2020-05-01 16:47:52] |
You might consider this a rediculous question, but i'm curious if Sierra could offer a custom TICK solution where: - i can provide the data feed - i can input the list of stocks to take into consideration and apply a weight to in the calculation of the net TICK Maybe we can already do this with a spreadsheet, but i'm curious if that would be able to perform as expected. |
[2020-05-01 18:51:55] |
It is supported. Refer to: Custom Calculated Symbols However, it is not practical if the list of symbols is large because the symbol would be quite large. There is a Symbol length limitation in Sierra Chart of 128 characters but we can remove that limit. It is not difficult. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-01 18:53:20
