Date/Time: Sun, 19 May 2024 16:56:18 +0000
Email Alert suddenly stopped working
View Count: 587
[2019-08-27 22:39:59] |
User885308 - Posts: 3 |
Hi, I was getting email alerts sent to an address ending @mms.cricketwireless.net. They worked perfectly for about 3 weeks. Can you check to see if your server has blocked the domain? If not,what may be the issue at hand. I have not alerts log errors. Formulas are all true. Everything in log says it was sent succesfully. Thank you |
[2019-08-28 04:39:39] |
There is not anything we can do from our side in regards to this. Our server certainly has not blocked that domain. It is the exact opposite. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-28 04:39:40] |
[2019-08-28 15:43:14] |
By opposite do you mean that your server has most likely been blocked?
[2019-08-28 17:19:18] |
Yes or just the emails are getting are getting quietly ignored. This is not unusual.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-28 17:19:44
