Date/Time: Sun, 19 May 2024 18:37:10 +0000
Auto Scale the ChartDOM to Tick Size
View Count: 1008
[2019-08-27 20:14:41] |
seandunaway - Posts: 214 |
I'd like to keep my Scale Increment set to 0 (Auto), so that it properly adjusts with the different Scale Ranges. However, when I Auto Scale the ChartDOM, doesn't it make sense to default it to the Tick Size like a TradeDOM? It's really helpful to quickly zoom in for execution and out for perspective and the scale to adjust proportionally. A chart and ladder all in one! attached (41 seconds) (it's less fun when i have to continually input 0.015625) Date Time Of Last Edit: 2019-08-27 21:22:42
autoscale chartdom to ticksize.gif / V - Attached On 2019-08-27 21:05:34 UTC - Size: 282.4 KB - 320 views |
[2019-08-28 06:35:08] |
Clearly the scale is being adjusted based on the Tick Size. This is obvious. But you may not see a label at every tick.
[2019-08-28 07:55:57] |
May we see a label at every tick when in DOM mode?
