Date/Time: Fri, 02 Oct 2026 21:30:35 +0000
How to display real-time market depth
View Count: 2370
| [2019-08-27 14:22:50] |
| User993629 - Posts: 3 |
Hi! I am testing your platform (trial version) but I have problem with market depth data. Really don't know where to find it and display on chart. Or am I wrong and it's not available? http://www.sierrachart.com/image.php?Image=1566914504850.png |
| [2019-08-27 17:30:22] |
That particular symbol, XAUUSD, does not provide market depth data. For what markets do you require market depth data for? We do plan to offer delayed CME futures contract data with market depth data in about a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 17:31:47
| [2019-08-27 20:14:49] |
I am interested with FOREX/CFD markets. Does any of instrument from that markets has real-time depth data ? On front page I see screenshots with those kind of data and that's why I'm asking: https://prnt.sc/oyby5h Even the sum of bids and asks transactions concluded in a given time period is sufficient for me. |
| [2019-08-28 06:35:49] |
For cash Forex and CFD markets, for market depth data you need to use LMAX: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-08-29 11:35:51] |
Thank you, works fine. However I have one more question because market depth values overlap. How to adjust it? http://www.sierrachart.com/image.php?Image=1567078491931.png |
| [2019-08-29 19:05:32] |
You have to expand, reduce the range of , the scale to see the Market Depth numbers. Refer to the following for how to do this: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-29 19:06:07
