Date/Time: Sun, 19 May 2024 16:56:15 +0000
tool bar text and symbols missing after updating to version 1978
View Count: 994
[2019-08-27 14:14:37] |
User575186 - Posts: 1 |
Please help. I cant see names or symbols of the toolbar since I updated my Application. New version installed 1978 32bit
Date Time Of Last Edit: 2019-08-27 14:33:34
[2019-08-27 17:10:09] |
You need to go to Global Settings >> Graphics Settings: Graphics Settings And adjust the Control Bar: Button Default Background color to what you want to use. Check the other colors for the control bar to be sure they are set as you require. This will solve the problem. Regarding images on Control Bar buttons, refer to this section here: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 17:17:12
