Date/Time: Sun, 19 May 2024 18:37:06 +0000
Attach Trade Order button
View Count: 625
[2019-08-27 13:58:27] |
User98657 - Posts: 304 |
Would it be possible to get a trade button added to check/uncheck the "Attach Trade Order" from the trade window? I'd also like to be able to highlght it in the "Checked" position.
[2019-08-27 17:33:44] |
Are you referring to the Use Attached Orders setting?
[2019-08-27 18:56:54] |
Yes
[2019-08-28 06:28:02] |
You can set up a Control Bar button for that: Control Bar When configuring a control bar it is listed on under the Trade Window Menu list. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
