Date/Time: Sun, 19 May 2024 21:02:08 +0000
Purchase of studies/indicators/oscillators
View Count: 2336
[2019-08-27 02:39:41] |
User837393 - Posts: 132 |
Hello, I’ve just purchase a study from a vendor, but now vendor is asking me for sierra chart account name. Is it common/safe practice? Best regards. |
[2019-08-27 10:46:57] |
Ackin - Posts: 1865 |
Yes, he has a protected library against stealing it. Without an account name, vendor can't authorize you in the list of authorized users (name only, NO password).
[2019-08-27 11:31:39] |
bradh - Posts: 859 |
To add to what Ackin said, this mechanism can also be used when subscribing to a custom study. A date can be set to disable access when the subscription expires or is canceled. Also a Service Level can be assigned on a per-user basis that unlocks different features of the code. You can read about it here: Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users Brad H ForgivingComputers.com |
[2019-08-27 17:25:47] |
Yes it is safe to provide your Sierra Chart Account Name.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 17:25:51
