Date/Time: Sun, 19 May 2024 19:22:41 +0000
Capturing SIM data for statistical analysis by an external application
View Count: 586
[2019-08-26 18:47:40] |
UserCD - Posts: 7 |
I'd like to run a simulation with say 5-10 studies and capture all relevant data for input into an external program like Matlab for analysis. Any ideas on how this capture can be done.
[2019-08-27 17:00:22] |
It sounds like the following study will do what you want: Write Bar and Study Data To File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
