Date/Time: Sun, 19 May 2024 14:15:09 +0000
DOM column question
View Count: 547
[2019-08-26 16:56:40] |
User378226 - Posts: 15 |
There is a "(1)" next the number in the "last" column, what is this "(1)" and is there a way to remove it?
Capture.JPG / V - Attached On 2019-08-26 16:50:11 UTC - Size: 58.48 KB - 243 views Attachment Deleted. |
[2019-08-26 18:28:19] |
You are not referring to the Sierra Chart software. This is the Transact software. For the Sierra Chart Trading DOM functionality, refer to: Chart Trading and the Chart DOM: Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-26 18:28:36
