Date/Time: Sun, 19 May 2024 21:13:33 +0000
Does the spreadsheet FORECAST(X, KnownYs, KnownXs) work?
View Count: 866
[2019-08-26 14:56:24] |
User183724 - Posts: 183 |
Does the spreadsheet FORECAST(X, KnownYs, KnownXs) work? Does anyone have an example they would share with me? thx Spreadsheet Functions |
[2019-08-27 08:04:43] |
We will put together an example for this.
[2019-08-27 16:25:12] |
thx. I tried several Excel examples I found....couldn't get any of them to work on SC spreadsheet. Even simple examples...thx again
[2019-08-27 20:53:12] |
John - SC Support - Posts: 31733 |
We have added an example and further explanation of the FORECAST function here: Spreadsheet Example Formulas and Usage: Using the FORECAST Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
