Date/Time: Sun, 19 May 2024 16:25:42 +0000
activate account
View Count: 576
[2019-08-26 14:36:14] |
User279204 - Posts: 2 |
please activate account
[2019-08-26 17:49:48] |
Sierra Chart - Max - Posts: 5618 |
Your trial is not restricted. Let us know if you are having any issues using the trial. Sierra Chart Support |
[2019-08-26 19:49:04] |
cant connect it says , cqg fix trading and cqg fix socket, do i need to put money in package service now?
[2019-08-27 00:02:00] |
We need you to update Sierra Chart to the current version following the instructions here: Software Download: Fast Update The above step is very important and must be followed. After that follow the CQG setup instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
