Date/Time: Sun, 19 May 2024 12:53:08 +0000
CQG Lag
View Count: 1525
[2019-08-26 13:51:32] |
User932698 - Posts: 1 |
My chart data is lagging since the open. Any suggestions?
[2019-08-26 17:14:50] |
Refer to help topic 4: Prices / Data Falling Behind You can use this data feed to avoid the lag: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
