Date/Time: Sun, 19 May 2024 12:53:10 +0000
Percentage from high
View Count: 898
[2019-08-26 11:51:08] |
User541156 - Posts: 67 |
In quote board column fields, I can see a "percent from high" field, but there is no "percent from low" field. Is there any way to add this column "percent from low"? Date Time Of Last Edit: 2019-08-26 11:51:40
2019-08-26_21-17-55.png / V - Attached On 2019-08-26 11:51:02 UTC - Size: 34.34 KB - 362 views |
[2019-08-26 17:19:17] |
You mean the opposite. There is no Percent from High. We will add that.
