Date/Time: Sun, 19 May 2024 15:10:05 +0000
Global Settings/General Settings/Select a File at Startup file list when using change
View Count: 532
[2019-08-26 11:08:19] |
IconBob - Posts: 61 |
Global Settings/General Settings/Select a File at Startup file list when using change is limited to 7 files. Has been restricted since build 1978
SC GEN SET.png / V - Attached On 2019-08-26 11:07:27 UTC - Size: 27.79 KB - 245 views |
[2019-08-26 23:07:39] |
The problem is the Chartbook's are not listed. We will solve that.
