Date/Time: Fri, 29 Mar 2024 01:18:46 +0000
Volume By Price
View Count: 519
[2019-08-26 07:37:38] |
User80177 - Posts: 29 |
Hi, Question on Volume By Price Study Settings > Ticks per Volume bar. I can't seem to set this to less than 5. Is it possible to set this to a lower number? Thanks |
[2019-08-26 10:21:39] |
Yes this is explained here: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
