Date/Time: Thu, 25 Apr 2024 08:48:00 +0000
bad tick on CQG data
View Count: 581
[2019-08-26 02:24:53] |
User88 - Posts: 40 |
Bad ticks on GF & GLE Futures data on Friday 23/08. Could you pls clean up the data. Thanks. |
[2019-08-26 02:45:22] |
We will check on this.
[2019-08-26 03:04:16] |
This is now resolved. Follow the instructions here: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
