Date/Time: Fri, 26 Apr 2024 17:13:24 +0000
Data Files folder location- multiple instances
View Count: 614
[2019-08-25 17:30:01] |
User63042 - Posts: 19 |
I run several instances. I keep the program on my SSD C drive. Recently I had to move the data files to my D drive as I was running out of space on the SSD C drive. I changed the data file location for each instance in General Settings. For the main instance the program remembers the data file location (D drive) stored under General Settings with "Always Use Data Folder within Main Folder" unticked. However for instance 2 and instance 3 program overwrites my General Settings when I close down. Each time I reopen it has returned to default settings of Data Files on C drive within Main Folder. Can this be corrected please or am I doing something wrong? |
[2019-08-25 21:35:41] |
The only way to solve this is you will need to move your Sierra Chart installation fully over to your D drive. Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-25 21:36:15
