Date/Time: Mon, 21 Sep 2026 09:37:31 +0000
[Programming Help] - Problem with indexing in a P&F chart
View Count: 916
[2019-08-25 16:13:41]
User119231 - Posts: 7
Hello
Could you please help me understand the following behaviour?
I am using a P&F 1-12 chart and I am trying to access each bar index with a simple for loop (I am posting the code below).
The problem is:
1) When I load more than 1 day in the chart the sc.Index does not start from 0 but from a random place way after the first bar.
Here I attach the first lines from the Message Log where I have loaded 5 days. The chart has 346 bars and the sc.Index starts
from 283.
Chart: CLU9-NYMEX Point & Figure 1-12 #22 | Study: TEST1 | i 128 ArraySize 347 sc.Index 283 | 2019-08-25 11:21:41.924 *
Chart: CLU9-NYMEX Point & Figure 1-12 #22 | Study: TEST1 | i 129 ArraySize 347 sc.Index 283 | 2019-08-25 11:21:41.924 *
Chart: CLU9-NYMEX Point & Figure 1-12 #22 | Study: TEST1 | i 130 ArraySize 347 sc.Index 283 | 2019-08-25 11:21:41.924 *
Chart: CLU9-NYMEX Point & Figure 1-12 #22 | Study: TEST1 | i 131 ArraySize 347 sc.Index 283 | 2019-08-25 11:21:41.924 *
2) I tried the same code in a time based chart and the platform freeze and then crash each time.
// Section 2 - Do data processing here
for (int i = 0; i < sc.Index ; ++i)
  SCString ExistingDrawingInfo;
  ExistingDrawingInfo.Format(" i %d ArraySize %i sc.Index %d", i, sc.ArraySize, sc.Index);
  sc.AddMessageToLog(ExistingDrawingInfo, 1);
* Autoloop has been set to 1
