Date/Time: Fri, 29 Mar 2024 10:19:39 +0000
tick charts
View Count: 1298
[2019-08-25 15:07:13] |
User143551 - Posts: 96 |
how can I make a 233 tick chart,or do u only have renko charts
[2019-08-26 09:22:05] |
Yes this is supported. The setting for these chart bars is Number of Trades per Bar. Refer to: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-26 20:00:21] |
when the es gets a little volume the charts stop the dome run ok when will serra and trans act get the sockets so the charts don't stop no one can trade I need to talk to someone there on the telephone
[2019-08-26 20:09:03] |
if I go back to using the bridge with transact the 1941 verson who do I pay I NEED TO TALK TO SOME ON THE PHONE 423 764 2005
[2019-08-26 20:10:08] |
DAY AFTER DAY I CANT TRADE BECAUSE OF THIS
[2019-08-27 07:03:15] |
The connectivity issue is going to be on the Transact side. We will give you a call.
[2019-08-27 15:44:34] |
SC Support - Posts: 1785 |
Can we give you a call in the next couple hours?
[2019-08-27 16:38:18] |
yes
