Date/Time: Sat, 20 Apr 2024 09:41:14 +0000
Showing an indicator value on the main chart
View Count: 759
[2019-08-25 12:56:26] |
User469312 - Posts: 95 |
Is it possible to have an indicator value (an example is the RSI value say its at 80 ish) display as an numerical value on the main chart? in one of the corners not just as it is below as a study? like the Countdown Timer or the Clock? Thank you in advance |
[2019-08-25 13:00:47] |
Ackin - Posts: 1863 |
Try this: Text Display For Study |
[2019-08-25 21:37:10] |
Yes use this study: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
