Date/Time: Fri, 26 Apr 2024 20:58:03 +0000
use-case examples for OpenChartOrGetChartReference, getChartNumber, setChartNumber
View Count: 713
[2019-08-24 19:54:35] |
Chad - Posts: 231 |
Hi SCE, are there additional use-case examples for sc.OpenChartOrGetChartReference, getChartNumber or setChartNumber, aside from the examples in ACS_Source\Studies.cpp? Basically I want to read a list of symbols (and any study names listed for each one) from a CSV file (using sc.OpenFile presumed), then assign these to a set of Chart windows...seems doing a 'watchlist scan' can't be done since the flexibility I need for study configs doesn't allow fixed settings to be done for each window. Would sc.OpenChartOrGetChartReference alone be able to achieve this objective? Date Time Of Last Edit: 2019-08-24 19:58:10
[2019-08-26 15:53:39] |
Chad - Posts: 231 |
On a separate note, is there a comprehensive list within the documentation (or a source script within \ACS_Source) of all members allowed for use within the sc.SetDefaults structure? i.e. sc.MaximumPositionAllowed, sc.SupportReversals, etc.
Date Time Of Last Edit: 2019-08-26 15:54:27
[2019-08-26 18:16:22] |
You cannot fully do what you want because you cannot add a study to a chart using ACSIL. Although we do have a function we are working on to add a Study Collection to a chart. In regards to the second post, no but complete information in regards to this is explained here: ACSIL Interface Members - Variables and Arrays: sc.SetDefaults Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-26 18:16:53
[2019-08-26 18:44:34] |
Chad - Posts: 231 |
Thanks, SCE. Any guesstimate on when the fcn for adding a Study Collection to a Chart will be released?
