Date/Time: Fri, 19 Apr 2024 01:01:03 +0000
Acsil sc.SetAttachedOrders()
View Count: 881
[2019-08-24 17:57:25] |
User565999 - Posts: 9 |
Hi team, the function sc.SetAttachedOrders() cant change the parent orderquantity in the trade window. OCO Settings are working. s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 4; NewOrder.OCOGroup1Quantity = 4; NewOrder.OrderType = SCT_ORDERTYPE_LIMIT; NewOrder.Target1Offset = 16*sc.TickSize; NewOrder.Stop1Offset = 8*sc.TickSize; sc.SetAttachedOrders(NewOrder); am i missing something? Thank you very much |
[2019-08-27 08:00:44] |
This will be solved in the next release. For now use this function: ACSIL Interface Members - Variables and Arrays: sc.TradeWindowOrderQuantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 08:01:36
