Date/Time: Fri, 29 Mar 2024 08:58:34 +0000
[User Discussion] - Bid & Ask Prices when there is not a trade
View Count: 1244
[2019-08-24 17:21:38] |
caligola - Posts: 116 |
Dear support, I see that the Bid & Ask Prices Study has a limitation: These Bid and Ask prices only update when there is a trade. Is there a study that save Bid and Ask prices when a bar closes? If it is not with a single study maybe with multiple studies or a spreadsheet. Thank You Date Time Of Last Edit: 2019-08-24 17:25:24
[2019-08-25 04:18:02] |
There are Data Recording Modes to include Bid and Ask updates which you can use. Refer to: Data Recording Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-25 04:18:09
[2019-08-26 14:43:06] |
What is the difference between -ALL and -BID_ASK_TRADE_SYNC ? -BID_ASK_TRADE_SYNC seems to be more complete but I don't get in what way they are different Thank You Date Time Of Last Edit: 2019-08-26 14:43:42
[2019-08-26 17:24:05] |
Both of those recording modes are documented here: Data Recording Modes -BID_ASK_TRADE_SYNC is the one we recommend you use. And also make sure this option on Chart >> Chart Settings is enabled: Load Bid/Ask Update Only Intraday Records Refer to: Chart Settings: Load Bid/Ask Update Only Intraday Records (Chart >> Chart Settings >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-25 08:13:11] |
Dear support, I would like to have a tip about CPU optimization of SC: I have a chartbook with 15 charts , all on the same symbol. Please note that only one chart has recording modes -BID_ASK_TRADE_SYNC. I would like to know which setup is better: 1) 14 charts with the standard symbol and 1 chart with the -BID_ASK_TRADE_SYNC suffix 2) all charts symbols with the -BID_ASK_TRADE_SYNC suffix There are any difference performance between the above configurations about: a) Chartbook opening time? b) CPU load during the day (more important)? c) RAM usage? thanks in advance |
[2019-10-30 10:52:07] |
1) 14 charts with the standard symbol and 1 chart with the -BID_ASK_TRADE_SYNC suffix 2) all charts symbols with the -BID_ASK_TRADE_SYNC suffix There are any difference performance between the above configurations about: a) Chartbook opening time? b) CPU load during the day (more important)? c) RAM usage? Could you please suggest a way to do this tests by my own? |
[2019-10-31 00:25:47] |
You really just have to go and do your own testing for this.
[2019-10-31 14:21:52] |
User915027 - Posts: 17 |
Do you have any tip about a third part software to measure CPU load and other performance stats?
