Date/Time: Fri, 29 Mar 2024 13:08:56 +0000
Futures spread chart no display
View Count: 841
[2019-08-24 11:10:37] |
seven0907 - Posts: 34 |
Hi, SC I tried different ways to set up two futures spread chart, but still one chart show only recent data corrected and the other chart no data display, could you help to review and fix it? thanks. 1: NG spread(nature gas): tried different studies and still no display 2: RB spread: recent days data corrected, but others data show different with IB plot. |
NG spread with no plot display.png / V - Attached On 2019-08-24 11:04:11 UTC - Size: 12.91 KB - 315 views RB Spread plot.png / V - Attached On 2019-08-24 11:04:15 UTC - Size: 12.66 KB - 231 views NG and RB spread in TWS.png / V - Attached On 2019-08-24 11:10:11 UTC - Size: 92.42 KB - 324 views |
[2019-08-26 18:21:02] |
The recommended way to do this is to use the Add Additional Symbol Study: Add Additional Symbol And then use this particular study to calculate the difference: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=3#Difference_-_Bar Note that the Chart 2 Number input with that study will refer to the same chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-26 18:21:38
[2019-08-27 02:56:46] |
Hi, SC I tried the add additional symbol method, looks like some spread only calculate recent contract, that means only 3-month data been calculated, could you help to investigate it? thanks. BTW: use add additional symbol method, I cant change study "Different bar" line color, only can remain green color. |
ZB-UB spread.png / V - Attached On 2019-08-27 02:55:23 UTC - Size: 17.79 KB - 209 views ZB-UB setting.png / V - Attached On 2019-08-27 02:55:29 UTC - Size: 42.32 KB - 236 views RB Spread.png / V - Attached On 2019-08-27 02:55:33 UTC - Size: 12.69 KB - 232 views |
[2019-08-27 07:36:04] |
Yes that is true, that when using Add Additional Symbol study you cannot use the Continuous Futures Contract setting for that additional symbol. So you need to use another chart and use the Difference (Bar) study. For the color settings, refer to: Color Settings for Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
