Date/Time: Sun, 02 Feb 2025 03:58:16 +0000
Font and background color of chart heading bar
View Count: 1759
[2019-08-24 04:16:59] |
Litz - Posts: 131 |
went thru global settings/graphic settings/fonts but could not determine which one controls the font of bar across the top of charts. currently grey background https://i.imgur.com/7kTj6Z3.png tia
[2019-08-24 22:22:04] |
If you are referring to the title bar of the chart, the colors and font, are controlled through the operating system. Otherwise, use the Chart Text font: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-24 22:22:13
[2019-08-25 00:08:59] |
Litz - Posts: 131 |
OK Windows 10 removed the feature that allows Title Bar font change but this free utility allows it https://winaero.com/ under advanced appearance settings/ window title bars works.
