Date/Time: Wed, 01 May 2024 21:55:33 +0000
sc.Index off by 1 on candle open on backtest replay
View Count: 567
[2019-08-24 03:04:53] |
User806682 - Posts: 10 |
Hello, Wondering if this is a bug or expected behavior. I have a study that will execute an order on the candle open, given that previous candle patterns match certain parameters. This works most of the time. But in rare cases, I find that sc.Index is off by 1, meaning it's not at the correct index for the new candle, while sc.ArraySize has been increased by 1 compared to the previous candle. This only happens sometimes during backtest replay and only once at the beginning of some candles. I'm currently handling it by doing this: if (sc.Index != sc.ArraySize-1) { return; } Thanks. |
[2019-08-24 10:13:50] |
There certainly is no bug in regards to that. For a full understanding of how this all works, refer to this page: Working with ACSIL Arrays and Understanding Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
