Date/Time: Tue, 23 Apr 2024 13:31:58 +0000
SierraChart crashes
View Count: 515
[2019-08-23 07:57:52] |
User941471 - Posts: 6 |
Hello Sierra Chart has been hanging around for about a week. It does not work anymore, Windows shows a bug fix for SierraChart to stop responding. The platform must then be closed and restarted. Can it be that I may have too many charts open? |
[2019-08-23 09:25:44] |
First refer to help topic 17 here: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface And then refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
