Date/Time: Fri, 19 Apr 2024 19:09:25 +0000
Add symbol for Interactive Brokers Ethanol futures -CME AC
View Count: 910
[2019-08-23 03:53:10] |
User834905 - Posts: 35 |
Please can the above contract be added to the symbol database or is there a way I can add it manually?
[2019-08-23 18:29:31] |
So did you want this added for Interactive Brokers?
[2019-08-24 00:09:37] |
yes if possible add it to Interactive Brokers.
[2019-08-24 02:38:47] |
Done.
