Date/Time: Sat, 20 Apr 2024 04:57:59 +0000
Connectivity to Interactive Brokers Data Feed
View Count: 526
[2019-08-22 17:04:04] |
User695161 - Posts: 1 |
Reading Internal Order ID file. | 2019-08-22 17:02:48.641 Reading Trade Orders file. | 2019-08-22 17:02:48.863 Reading Trade Positions file. | 2019-08-22 17:02:48.864 Reading Account Balance file. | 2019-08-22 17:02:48.864 UDPListener (1480). Port 22904 | Listening on UDP port 22904. | 2019-08-22 17:02:48.930 Software version: 1978 64-bit | 2019-08-22 17:02:48.930 Usage end date: 2019-09-06 | 2019-08-22 17:02:48.930 Enabled for: Advanced Features 2. | 2019-08-22 17:02:48.930 Enabled for: Sierra Chart Historical Data Service. | 2019-08-22 17:02:48.930 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-22 17:02:48.930 Current selected Data/Trading service: Interactive Brokers | 2019-08-22 17:02:48.930 Custom symbol settings values: enabled | 2019-08-22 17:02:48.930 Chart Update Interval: 500 | 2019-08-22 17:02:48.930 Intraday Data Storage Time Unit: 1 | 2019-08-22 17:02:48.930 Time Zone: +00:00:00 (UTC+00) | 2019-08-22 17:02:48.930 2019-08-22 18:02:48 Local computer time | 2019-08-22 17:02:48.930 2019-08-22 17:02:48 Local computer time in UTC | 2019-08-22 17:02:48.930 2019-08-22 17:02:48 Local computer time in SC Time Zone | 2019-08-22 17:02:48.930 2019-08-22 17:02:45 Server time in UTC | 2019-08-22 17:02:48.930 Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-08-22 17:02:48.930 Program path: C:\SierraChart\ | 2019-08-22 17:02:48.930 Data Files path: C:\SierraChart\Data\ | 2019-08-22 17:02:48.930 OS Version Number: 10.0 | 2019-08-22 17:02:48.931 Locale Setting: C | 2019-08-22 17:02:48.931 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-22 17:02:48.932 Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2019-08-22 17:02:48.932 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-22 17:02:48.962 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-22 17:02:49.005 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-22 17:02:49.006 Received 5 login tokens. | 2019-08-22 17:02:49.139 Symbol settings MD5 received. Request ID: 1. | 2019-08-22 17:02:49.219 Symbol settings are up-to-date for interactive_brokers.trading. | 2019-08-22 17:02:49.219 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-08-22 17:02:49.380 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-08-22 17:02:49.417 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-08-22 17:02:49.417 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-08-22 17:02:50.931 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-08-22 17:02:50.932 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-22 17:02:51.396 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-22 17:02:51.433 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-22 17:02:51.433 Interactive Brokers | Connecting to 7496:7496 | 2019-08-22 17:02:54.148 Error getting address info for 7496. Windows error code 11001: No such host is known. | 2019-08-22 17:02:56.402 * Interactive Brokers | Failed to connect to the data and trade server. | 2019-08-22 17:02:56.402 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-08-22 17:02:56.402 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-22 17:02:56.402 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-22 17:02:56.402 Interactive Brokers | Disconnected. | 2019-08-22 17:02:56.474 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-22 17:02:56.474 Interactive Brokers | Connecting to 7496:7496 | 2019-08-22 17:02:59.474 Error getting address info for 7496. Windows error code 11001: No such host is known. | 2019-08-22 17:03:01.727 * Interactive Brokers | Failed to connect to the data and trade server. | 2019-08-22 17:03:01.727 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-08-22 17:03:01.727 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-22 17:03:01.727 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-22 17:03:01.727 Interactive Brokers | Disconnected. | 2019-08-22 17:03:01.746 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-22 17:03:01.746 Interactive Brokers | Connecting to 7496:7496 | 2019-08-22 17:03:04.741 Error getting address info for 7496. Windows error code 11001: No such host is known. | 2019-08-22 17:03:06.993 * Interactive Brokers | Failed to connect to the data and trade server. | 2019-08-22 17:03:06.993 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-08-22 17:03:06.993 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-22 17:03:06.993 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-22 17:03:06.993 Interactive Brokers | Disconnected. | 2019-08-22 17:03:07.008 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-22 17:03:07.008 |
[2019-08-22 17:44:51] |
You need to set Global Settings >> Data/Trade Service Settings >> Service Settings >> Server Address and Port to: 127.0.0.1:7496
