Date/Time: Thu, 25 Apr 2024 12:27:33 +0000
how can i connect transact account to this account?
View Count: 632
[2019-08-22 16:21:32] |
User588427 - Posts: 1 |
yeah i read that link, so i'm a bit worried that i actually made sierra Version 1978 to work with transact , while my friend that use the same transact working on 1941 and even someone work on 18xx versions. How can that be? Is the data true? |
[2019-08-22 17:30:06] |
Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions As long as you do not need to trade from Sierra Chart, when using Transact you can use the latest version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
