Date/Time: Fri, 29 Mar 2024 14:16:21 +0000
Trade DOM
View Count: 578
[2019-08-22 10:06:04] |
User231861 - Posts: 9 |
Hello, please ther is a link where is possible to download personalized DOM? Or chartbooks? I'm more interested in DOM. Thank you for your help! |
[2019-08-22 10:39:11] |
Not really. You need to configure Sierra Chart as you require. But there is the capability to share files between users and that is documented here: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-22 16:15:58] |
ticinotrader - Posts: 377 |
You can check on youtube for the keywords: sierrachart DOM I have posted instructional videos there earlier about setting up DOMs from the scratch. |
[2019-08-26 13:53:23] |
Thank you very much!!
