Date/Time: Sun, 02 Feb 2025 03:50:54 +0000
Can you please put something in the interface that tells you a new version is available?
View Count: 584
[2019-08-22 03:25:24] |
cmet - Posts: 598 |
There's literally no way to know when new versions are released unless you go to the software download page on your website. This possibly is the only software I've ever used that doesn't notify you of updates every time they're released. Perhaps you could consider one of the following or something similar: -Putting a notification area on the far right of the control bar that tells you a newer version is available and the version number -Color the DCV button in the control bar Red or some other color when a newer version is available -Have the pop up at login occur on every new release and not just randomly for some releases but not others Date Time Of Last Edit: 2019-08-22 03:26:09
[2019-08-22 06:42:21] |
We hope it is the only software that does not regularly notify you of updates. If there are important updates, we will put out a notice as needed. And certainly about approximately about every three months, older versions will get an update notice.
