Date/Time: Thu, 25 Apr 2024 15:09:46 +0000
HK STOCK DATA FEED
View Count: 1042
[2019-08-22 00:53:32] |
Laurunrun - Posts: 11 |
I have read that if I am using IB, I can load those HK STOCK data however, I cannot find the symbol. Pls advise me how to arrange it with thanks. also, can I see HANG SENG INDEX OPTION DATA 2 I have subscribed all these data in IB But I don't know how to work it on SIERRA CHART. pls advise me with thanks. |
[2019-08-22 06:10:53] |
For Hong Kong stocks and options you will need to manually enter the symbols when you want to open the charts. This is all fully documented on this page: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-22 06:11:27
