Date/Time: Thu, 25 Apr 2024 07:17:20 +0000
Horizontal spacing on a chart (compressing even more)
View Count: 629
[2019-08-21 20:45:43] |
User58241 - Posts: 24 |
I realize that you are not taking suggestions on new features, although what I would like to suggest would be an improvement on an existing function. Currently I use charts that go down to 10 seconds, the reason being that I need to see where certain pivots occur as looking at a 1 minute chart does not show sufficient detail. What I would like to see is a 10 second chart able to be compressed more than is currently possible. I use the scroll wheel to expand and compress chart spacing as needed. However, charts can only be compressed down to a “0” level (when you look at the indicator in the lower right level of the scale). If there was a way to compress price data on the chart even more in a 10 second (or other small time frame) chart, even though price bars may overlap, I would not only be able to see where pivots occur, but also more context. This is nothing urgent and I am getting along without it. But if this were possible, it would definitely be helpful. Thank you for your consideration. As always, I am appreciative of what you have done and are doing to make this such a great charting program! Dan |
