Date/Time: Fri, 29 Mar 2024 10:14:03 +0000
spreadsheet formulas gone
View Count: 565
[2019-08-21 19:31:03] |
User57210 - Posts: 121 |
I had a very important set of spreadsheets that ran for a chart. I haven't opened it in a while, migrated computers, and now I'm trying to load it up (without success). I have the .StdyCollct file, and the .Cht file. Is this not enough? I also have the Sierra3.cfg file but have not tried to use it, as I didn't think it would be needed. My guess is I made a grave mistake here not saving the spreadsheet files individually? |
[2019-08-21 19:43:59] |
There are backups of the spreadsheet files made in the Backups subfolder of the Sierra Chart installation folder. Check the backups. A spreadsheet can operate completely independent of a study collection, a Chartbook file and certainly the main configuration file. There is no dependency on any of those files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
