Date/Time: Thu, 28 Mar 2024 18:25:22 +0000
CME Data error
View Count: 472
[2019-08-21 16:30:22] |
User721518 - Posts: 2 |
Hi, before i can click delete and download data, sierra chart just shuts down automatically. what is wrong? |
[2019-08-21 16:49:21] |
Start Sierra Chart again and disable Open Files on Startup on the Login window. And enable Safe Mode. Do not open any of your Chartbooks. Open Intraday charts for the symbols you use through File >> New/Open Intraday Chart. And then follow the instructions below: To re-download the data in the chart to correct the data error during the 17:00 US Eastern time hour on 2019-08-20: Scroll the chart back in time to that data error then right-click on the chart before the data error and select Delete and Download Data. You only need to do this once per symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
