Date/Time: Sat, 20 Apr 2024 03:28:55 +0000
[User Discussion] - Volume Profile is not recognizable on a daily view
View Count: 569
[2019-08-21 16:10:19] |
User699988 - Posts: 8 |
Hello, I have the following problem: Every time I load the VOLUME BY PRICE study on a daily view, the Volume Profile looks strange and not right. It works on every other time setting (minutes, hours, weeks). Why not on a daily view? Many thanks in advance! http://www.sierrachart.com/image.php?Image=1566403749506.png |
[2019-08-21 18:40:41] |
The reason for this is explained here: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts So it makes sense when you have a volume profile with a one day time period, that on a 1 Day bar, all the volume levels will be the same. You need to use an Intraday chart instead. Refer to: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
