Date/Time: Wed, 24 Apr 2024 18:20:48 +0000
My GC dom is empty on the sell side.
View Count: 580
[2019-08-20 20:18:58] |
madness99 - Posts: 35 |
Here is a picture of my gold dom Thanks J |
gold dom.JPG / V - Attached On 2019-08-20 20:15:35 UTC - Size: 52.46 KB - 217 views |
[2019-08-21 06:39:38] |
Most likely you have the Sell Order Column displayed rather than the Ask Size/Sell Column. Go to Trade >> Customize Chart/Trade DOM Columns and add the Ask Size/Sell Column, it will automatically remove the other one. Refer to the following documentation for customizing the displayed columns: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
