Date/Time: Fri, 26 Apr 2024 18:36:46 +0000
Candle Body
View Count: 579
[2019-08-20 17:46:42] |
MazSalih - Posts: 4 |
Hi I have been through the studies and unable to source what I'm after. Is there a way I can colour a candle if it's body is 50% less than the range? |
[2019-08-20 20:47:38] |
Yes can be done with this study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
