Date/Time: Wed, 01 May 2024 22:06:52 +0000
MME - MSCI Emerging market index future (ICE)
View Count: 920
[2019-08-20 17:35:16] |
User210422 - Posts: 19 |
Hi, i cannot find this symbol. I have cgq fix for trading and SC data for realitme. Thanks.
Date Time Of Last Edit: 2019-08-21 14:36:32
[2019-08-22 18:04:24] |
any help on this one?
[2019-08-22 22:41:49] |
Yes we will get try to get this added today.
[2019-08-26 11:21:07] |
ok, do i have to refresh symbols list. I tried that and no luck so far.
[2019-08-26 16:42:57] |
We have not yet finished with adding this.
[2019-08-27 01:58:14] |
This symbol has now been added: F.US.MME?## Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
