Date/Time: Fri, 29 Mar 2024 11:14:15 +0000
[Programming Help] - Volume Profile Tool relative length and color
View Count: 494
[2019-08-20 17:28:45] |
User796323 - Posts: 5 |
Could you please give an option to make Volume Profile Tool line 73 and line 109 color and length relative to other profiles when drawn manually? This way we can compare profiles to each other.
[2019-08-21 06:47:27] |
This is not going to come.
