Date/Time: Fri, 29 Mar 2024 07:44:11 +0000
Intraday chart - limited days loaded
View Count: 597
[2019-08-20 13:42:08] |
manfretto - Posts: 117 |
Hi, I had to delete and download all data (as missed a few latest bars due to TWS change between paper and real account). However, all data is downloaded starting from July 30. I am not able to download more historical data for intraday intervals. Chart settings -> Main Settings -> Date range in file From is: 2019-07-30 (not able to change as after 'Apply' it backs to July 30) Days to load set to: 250. Please help. Best Regards, manfretto |
[2019-08-20 16:48:35] |
Follow the instructions here to use the Sierra Chart Historical Data Service: Interactive Brokers Trading Service: Using Sierra Chart Historical Data (Using Sierra Chart Historical Data) And then follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-20 16:49:05
[2019-08-21 09:03:46] |
I have followed the steps above. Finally, I downloaded data again and see no fix - the data starts from July 31 (11.00 CET) It looks like it allows to download only last fixed amount of bars. Is there any limitation from Interactive brokers recently introduced? May I share the log with you? May it help? If yes, let me know how to do this.
[2019-08-21 19:28:57] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-22 06:35:09] |
Message log has just been sent for analysis. Let me know if you need anything else for investigation. |
[2019-08-22 06:44:22] |
You need to follow the instructions here to use the Sierra Chart Historical Data Service: Interactive Brokers Trading Service: Using Sierra Chart Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-22 12:02:11] |
It works now. Thank you.
