Date/Time: Tue, 23 Apr 2024 20:58:34 +0000
General Trade Settings
View Count: 758
[2019-08-20 13:10:53] |
User657856 - Posts: 61 |
I cannot send You the picture General Trade Settings, How to do it? Sincerely Bogdan Nominaniuk |
[2019-08-20 14:38:05] |
What is the question regarding General Trade Settings? If you have a problem where you are trying to open it and it does not display, then update to the current version of Sierra Chart following these instructions here: Software Download: Fast Update We implemented a workaround of an operating system issue where sometimes the operating system fails to show a dialog window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-20 14:38:41
