Date/Time: Sun, 24 Nov 2024 20:31:04 +0000
ERROR MESSAGE after i downloaded latest version.
View Count: 1306
[2013-12-08 18:14:12]
DAVID SUDDUTH JR - Posts: 34
Software version: 1061 | 2013-12-08 13:04:41
Usage end date: 2014-11-26 | 2013-12-08 13:04:41
Enabled for: Sierra Chart Historical Data Service. | 2013-12-08 13:04:41
Enabled for: Sierra Chart Real-Time Futures Data Service for Trading Services. | 2013-12-08 13:04:41
Received 2 data feed usernames. | 2013-12-08 13:04:41
Allow Support for Sierra Chart Data Feeds is enabled. | 2013-12-08 13:04:41
Active service: TD Ameritrade | 2013-12-08 13:04:41
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-08 13:04:41
2013-12-08 12:04:41 Local computer clock time | 2013-12-08 13:04:41
2013-12-08 18:04:41 GMT time | 2013-12-08 13:04:41
2013-12-08 13:04:41 Time zone adjusted time | 2013-12-08 13:04:41
Time difference to server time: 15 seconds. | 2013-12-08 13:04:41
Program path: C:\SierraChart\ | 2013-12-08 13:04:41
Data Files path: C:\SierraChart\Data\ | 2013-12-08 13:04:41
OS Version Number: 6.1 | 2013-12-08 13:04:41
Checking for new symbol settings for tda | 2013-12-08 13:04:41
Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-08 13:04:44
Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-08 13:04:45
Error loading custom studies DLL: C:\SierraChart\Data\ECIVwapV0.7.dll. Windows error code 126: The specified module could not be found. | 2013-12-08 13:04:45
Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-08 13:04:46
Error loading custom studies DLL: C:\SierraChart\Data\ECIVwapV0.2.dll. Windows error code 126: The specified module could not be found. | 2013-12-08 13:04:46
Record has been filtered due to large range while loading Intraday data for QCL#C | 2013-12-08 13:04:50
No SC real-time data feed mapping found for symbol: QCL#C | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: QCLF14 | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: QCLG14 | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: QCLH14 | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: QCLJ14 | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: QCLK14 | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: @DX# | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: @ES# | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: SPX.XO | 2013-12-08 13:04:51
No SC real-time data feed mapping found for symbol: @US# | 2013-12-08 13:04:51
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\DI6D.Z.scid | 2013-12-08 13:04:52
Mapping /ESZ3 to ESZ3. Service code: cme | 2013-12-08 13:04:52
HD Request # 2 - Downloading Intraday chart data for /ESZ3 to the file [ESZ3.scid. Service: cme | 2013-12-08 13:04:52
HD Request # 2 - Last Date-Time in file: 2013-12-06 17:14:59.0 | 2013-12-08 13:04:52
HD Request # 2 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 13:04:52
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 13:04:52
The network socket is connected. | 2013-12-08 13:04:52
HD Request # 2 - Sending historical data logon request message. | 2013-12-08 13:04:52
Record has been filtered due to large range while loading Intraday data for QCL#C | 2013-12-08 13:04:52
HD Request # 2 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 13:04:52
HD Request # 2 - Decompressing data. | 2013-12-08 13:04:52
HD Request # 2 - Receiving Intraday data for /ESZ3 starting at 2013-12-06 17:14:59 | 2013-12-08 13:04:52
The network socket for historical data has been closed. | 2013-12-08 13:04:52
HD Request # 2 - Historical data for /ESZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 13:04:52
HD Request # 2 - Received 36 records from 2013-12-06 17:14:59 to 2013-12-06 17:14:59 (0.0 seconds) and wrote 0 records for /ESZ3 | 2013-12-08 13:04:52
HD Request # 2 - Intraday download COMPLETE for /ESZ3 | 2013-12-08 13:04:52
No SC real-time data feed mapping found for symbol: $SPX.X | 2013-12-08 13:04:52
Connecting to TD Ameritrade... | 2013-12-08 13:04:53
Logging in... (Step 1 of 3) | 2013-12-08 13:04:53
HD Request # 3 - Downloading Intraday chart data for $NVLF to the file $NVLF.scid. Service: ddf | 2013-12-08 13:04:53
HD Request # 3 - Last Date-Time in file: 2013-12-06 18:59:59.0 | 2013-12-08 13:04:53
HD Request # 3 - Using server: ds5.sierracharts.com port 10149 | 2013-12-08 13:04:53
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-08 13:04:53
The network socket is connected. | 2013-12-08 13:04:53
HD Request # 3 - Sending historical data logon request message. | 2013-12-08 13:04:53
No SC real-time data feed mapping found for symbol: ESZ13 | 2013-12-08 13:04:53
HD Request # 4 - Downloading Historical Daily chart data for ESZ13. Starting date: 2013-12-05. Service: tda | 2013-12-08 13:04:53
HD Request # 4 - Using user account. | 2013-12-08 13:04:53
HD Request # 4 - Requesting historical Daily data for ESZ13 starting at 2013-12-04 | 2013-12-08 13:04:53
TD Ameritrade: Authorized for streamer data. | 2013-12-08 13:04:53
TD Ameritrade: Getting streamer information. (Step 2 of 3) | 2013-12-08 13:04:53
Mapping /6EZ3 to 6EZ3. Service code: cme | 2013-12-08 13:04:53
TD Ameritrade: Requesting message key for account activity streamer (Step 3 of 3) | 2013-12-08 13:04:53
HD Request # 4 - Receiving historical Daily data for ESZ13 starting at 2013-12-04 | 2013-12-08 13:04:53
Writing historical Daily data for ESZ13 to the file ESZ13.dly | 2013-12-08 13:04:53
HD Request # 4 - Received 3 records from 2013-12-04 00:00:00 to 2013-12-06 00:00:00 (3.0 days) and wrote 2 records for ESZ13 | 2013-12-08 13:04:53
HD Request # 4 - Daily download COMPLETE for ESZ13 | 2013-12-08 13:04:53
HD Request # 3 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 13:04:53
No SC real-time data feed mapping found for symbol: E6Z13 | 2013-12-08 13:04:53
HD Request # 5 - Downloading Historical Daily chart data for E6Z13. Starting date: 2013-12-05. Service: tda | 2013-12-08 13:04:53
HD Request # 5 - Using user account. | 2013-12-08 13:04:53
HD Request # 5 - Requesting historical Daily data for E6Z13 starting at 2013-12-04 | 2013-12-08 13:04:53
HD Request # 3 - Decompressing data. | 2013-12-08 13:04:53
HD Request # 3 - Receiving Intraday data for $NVLF starting at 2013-12-06 18:59:59 | 2013-12-08 13:04:53
The network socket for historical data has been closed. | 2013-12-08 13:04:53
HD Request # 3 - Historical data for $NVLF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 13:04:53
HD Request # 3 - Received 1 record from 2013-12-06 18:59:59 to 2013-12-06 18:59:59 (0.0 seconds) and wrote 0 records for $NVLF | 2013-12-08 13:04:53
HD Request # 3 - Intraday download COMPLETE for $NVLF | 2013-12-08 13:04:53
HD Request # 6 - Downloading Intraday chart data for /6EZ3 to the file [6EZ3.scid. Service: cme | 2013-12-08 13:04:53
HD Request # 6 - Last Date-Time in file: 2013-12-06 16:59:57.0 | 2013-12-08 13:04:53
HD Request # 6 - Using server: scdf1.sierracharts.com port 10149 | 2013-12-08 13:04:53
HD Request # 5 - Receiving historical Daily data for E6Z13 starting at 2013-12-04 | 2013-12-08 13:04:53
Writing historical Daily data for E6Z13 to the file E6Z13.dly | 2013-12-08 13:04:53
HD Request # 5 - Received 3 records from 2013-12-04 00:00:00 to 2013-12-06 00:00:00 (3.0 days) and wrote 2 records for E6Z13 | 2013-12-08 13:04:53
HD Request # 5 - Daily download COMPLETE for E6Z13 | 2013-12-08 13:04:54
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 13:04:54
The network socket is connected. | 2013-12-08 13:04:54
HD Request # 6 - Sending historical data logon request message. | 2013-12-08 13:04:54
HD Request # 6 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 13:04:54
HD Request # 6 - Decompressing data. | 2013-12-08 13:04:54
HD Request # 6 - Receiving Intraday data for /6EZ3 starting at 2013-12-06 16:59:57 | 2013-12-08 13:04:54
The network socket for historical data has been closed. | 2013-12-08 13:04:54
HD Request # 6 - Historical data for /6EZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 13:04:54
HD Request # 6 - Received 5 records from 2013-12-06 16:59:57 to 2013-12-06 16:59:57 (0.0 seconds) and wrote 0 records for /6EZ3 | 2013-12-08 13:04:54
HD Request # 6 - Intraday download COMPLETE for /6EZ3 | 2013-12-08 13:04:54
TD Ameritrade: Connected. | 2013-12-08 13:04:54
Mapping /6EZ3 to 6EZ3. Service code: cme | 2013-12-08 13:04:54
SC Data Service - Starting real-time market data updates for: 6EZ3 | 2013-12-08 13:04:54
SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 13:04:54
HD Request # 7 - Downloading Intraday chart data for /6EZ3 to the file [6EZ3.scid. Service: cme | 2013-12-08 13:04:54
HD Request # 7 - Last Date-Time in file: 2013-12-06 16:59:57.0 | 2013-12-08 13:04:54
HD Request # 7 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 13:04:54
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 13:04:54
HD Request # 7 - Sending historical data logon request message. | 2013-12-08 13:04:54
SC Data Service: Connected to server. | 2013-12-08 13:04:54
SC Data Service: Sending logon request message. | 2013-12-08 13:04:54
HD Request # 7 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 13:04:54
HD Request # 7 - Decompressing data. | 2013-12-08 13:04:55
HD Request # 7 - Receiving Intraday data for /6EZ3 starting at 2013-12-06 16:59:57 | 2013-12-08 13:04:55
The network socket for historical data has been closed. | 2013-12-08 13:04:55
SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 13:04:55
Socket closed. No error. | 2013-12-08 13:04:55
SC Data Service: Disconnected from the server. | 2013-12-08 13:04:55
SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 13:04:55
HD Request # 7 - Received 7 records from 2013-12-06 16:59:57 to 2013-12-06 16:59:57 (0.0 seconds) and wrote 0 records for /6EZ3 | 2013-12-08 13:04:55
HD Request # 7 - Intraday download COMPLETE for /6EZ3 | 2013-12-08 13:04:55
Real-time Intraday chart data file updates started for /6EZ3 | 2013-12-08 13:04:55
Date Time Of Last Edit: 2013-12-08 19:28:29
[2013-12-08 19:28:04]
This is now resolved.
